SpotlightConverting a truss into a symbol
Command
Workspace: Path
Convert Truss to Symbol
Design Suite: Entertainment > Rigging/Braceworks
Spotlight: Spotlight > Rigging/Braceworks
If you're not performing Braceworks calculations, you may wish to convert a truss into a symbol and use that in the drawing instead. This can improve performance if you have a large number of trusses. However, if you are performing calculations, you must use actual truss objects, not converted symbols.
To convert a truss to a symbol:
Select the truss (or multiple truss objects) to convert.
Select the command.
An alert opens, informing you how many objects were converted.
Each type of truss is converted to a hybrid symbol. The symbol is named after the original truss name.
Advantages of symbols
Placing trusses
Specifying cross section data
Connecting rigging with the Insert Connection tool
Concept: Creating a connected rigging system
Modifying truss symbol data
