Shaded options
Command
Path
View bar
Shaded Options
View > Rendering
Use the Shaded render mode to create good-quality rendering previews that are fast and interactive. Showcase rendering (Spotlight required) is based on Shaded mode.
Shaded options control the level of detail and other effects in rendered images, which in turn affects the render speed (less detail renders faster). Changes to the shaded options prompt immediate re-rendering when in shaded render mode. These settings apply only to the current drawing; they remain in effect in the current drawing until the settings are changed. Shaded options are also available as part of Shaded and Showcase render styles; see Render styles and Creating render styles. A render style allows parameters to be saved as a resource to be re-applied later and shared between files. The current shaded settings are saved when you create a template (see Concept: Templates).
For sheet layer viewports and section viewports, additional depth cueing options are available. Depth cueing in Shaded render mode adjusts object fill opacity to indicate distance from the camera. This provides a more realistic rendering for perspective and orthogonal views; see Applying depth cueing to a viewport. To set depth cueing for a selected viewport, click Background Render Settings on the Object Info palette; when the Shaded Options dialog box opens, a Depth Cueing tab is available.
Shaded render mode has features that help you to preview and adjust a scene before it is rendered with Renderworks render modes.
Turn on Shadows and the lighting and reflection options to understand the effect of multiple lighting options, including Renderworks backgrounds, in the rendered drawing.
Before Vectorworks 2023, Shaded mode rendered up to eight lights in a drawing; additional light objects had no effect. Similarly, only eight lights were allowed to cast shadows before Vectorworks 2024. To preserve the light setup in Shaded renderings of older files, select Limit Shaded render mode to 8 lights and Limit Shaded render mode to 8 shadows on the Document preferences Display tab (see Document preferences: Display tab).
Turn on the Draw edges feature to outline objects more clearly in the rendered drawing; these edges are similar to those in the Hidden Line render mode.
Turn on the interactive Shadows feature to see how the shadows fall with different types of lighting and adjust the lights.
Shaded rendering can display the following types of Renderworks backgrounds: One Color, Two Color, Image, Panoramic Image, and Physical Sky. It cannot display Cloud. (See Creating Renderworks backgrounds for details.)
Shaded render mode is used during viewing operations such as flyovers and walkthroughs when a Renderworks mode is in effect. Shaded also previews a rendered scene before a Renderworks render has completed.
For smoother rendering of mesh objects, enable mesh smoothing for the entire document in the document preferences (see Document preferences: Display tab) or for selected meshes on the Render tab of the Object Info palette (see Managing object textures from the Object Info palette).
To set the shaded options:
Select the command.
Alternatively, if a different render mode is active, select the command under Options For Other Render Modes in the Current Render Mode menu on the View bar. From the Object Info palette of a selected viewport that uses Shaded rendering for the background render mode, click Background Render Settings.
The Shaded Options dialog box opens; set the parameters.
Parameter
Description
General
Textures
Renders object textures; this provides better detail and is usually enabled, but it takes longer to render.
Some texture properties are intended to be used with Realistic RS render styles or Renderworks render modes. In Shaded mode, you will see an approximation of the appearance, which may be different from the appearance in Realistic RS render styles and Renderworks render modes.
Colors
When selected, renders colors, and textures with colors; deselect to render colors as white
Anti-aliasing
Filters the rendering and reduces pixelated edges; this option is only available if the graphics card supports the feature
Shadows
Objects in the drawing cast shadows on other objects
On ground only
Drawing objects cast shadows on a plane at the lowest point in the drawing—which is usually the active layer plane—but not on other objects
Draw edges
Renders objects with lines drawn around the edges, similar to the lines in the Hidden Line Render mode. Edges are drawn where objects meet; break up an object into multiple objects if more edges are needed.
Edge thickness (pixels)
Enter a value between 1–16 pixels for the edge thickness
Crease angle
If Draw edges is selected, enables crease edges at divergent surfaces; set the Threshold angle at which to start showing crease edges
Environment lighting
Uses the active Renderworks background (if any) as an ambient light source for the rendering (see Concept: Renderworks backgrounds).
Environment lighting's brightness can be controlled in the Ambient Info section of the Lighting Options dialog box.
Environment reflections
Uses the active panoramic image or physical sky type Renderworks background (if used) as a source for reflections off surfaces (see Concept: Renderworks backgrounds).
If the active background is not a panoramic image or physical sky, the default Renderworks gray environment background is used.
Object reflections
Allows objects to reflect other nearby objects
Lighting Options
Opens the Lighting Options dialog box; see Setting lighting options
Background Options
Opens the Set Renderworks Background dialog box; see Applying Renderworks backgrounds
Camera
See Placing a Renderworks camera for descriptions of the available effects. If a Renderworks camera sets the active view, the camera's effects override the Shaded options settings.
Depth of field
Uses the depth of field options
Focus Distance
Enter the focus distance numerically, or click Click to Set Focus Distance to define the focus distance based on objects in the drawing
(Design layers only)
Click To Set Focus Distance Cursor
Click to define the focus distance based on objects in the drawing; the cursor changes to indicate the operation is active. Click in the drawing to set the distance.
Exposure
Uses the exposure options
ISO Film Speed
Select an ISO film speed
Shutter Speed
Select the shutter speed, or select Custom Speed
Custom Speed (s)
If Shutter Speed is set to Custom Speed, enter a custom value
F-Stop
Select a value, or select Custom F-Stop
Custom (f/#)
If F-Stop is set to Custom F-Stop, enter a custom value equal to or greater than 0.01
Bloom (%)
Enter a bloom percentage; values greater than 100% are accepted
Quality
Details
Specifies the quality level for faceting of curved geometry; a low setting renders faster
Shadows
If Shadows is selected, select the level of quality for the shadow edges (a low setting uses less memory and renders faster)
Depth Cueing
Available when the dialog box is opened from the Object Info palette of a sheet layer viewport or section viewport. See Applying depth cueing to a viewport.
Rendering modes
