ArchSpot.pngCreating seating sections
Tool
Workspace: Tool set
Seating Section
●       Architect: Furn/Fixt
●       Spotlight: Event Design
Use the Seating Section tool to design seating sections in a variety of configurations. You can create features such as rises and custom numbering plans, edit individual seats as needed to create exactly the arrangement you need, and then output the data to editable reports included with Vectorworks. Use the Aisle tool (see Adding aisles to seating sections; Spotlight required) to insert aisles that interact with the seating section. Quick editing capabilities allow you to change specific elements of the plan without using the processor resources to redraw the entire seating section.
You can use a seating section style from the Vectorworks content or create a custom seating section style to quickly create multiple seating sections with the same settings; see Concept: Plug-in object styles.
To draw a seating section object, either use the tool or create a polyline and then select the Create Objects from Shapes command (see Creating objects from shapes). If this command is used, a default focus line is placed and can be moved manually into the desired location.
Use the Data Tag tool after creating a seating section to add a label; see Using data tags.
The Seating Section tool offers the following modes:
Mode
Description
Create from Shape
Converts an existing polyline, polygon, rectangle, circle, or arc to a seating section and applies the current preference settings
Oval
Creates a round seating section
Rectangle
Creates a rectangular seating section
Polyline
Draws a seating section using the selected polyline creation options
Polyline creation options
Selects the method for drawing the polyline upon which the object is based; see Creating polylines
Style
Opens the Resource Selector to select a resource for placement; double-click a resource to activate it
Preferences
Sets the default parameters that are used for each new seating section
To create a seating section:
1.      Click the tool and mode.
2.Do one of the following:
●       Click Style on the Tool bar to select a resource from the Resource Selector.
●       Click Preferences to open the Seating Section Preferences dialog box and specify the tool’s default parameters as described in Seating Section settings.
The parameters can be edited later in the Object Info palette as described in Editing seating sections, or in the Seating Section Settings dialog box.
3.Do one of the following:
●       If using Create from Shape mode, move the mouse over a previously drawn shape until it is highlighted. Click to select it.
●       If using Rectangle, Oval, or Polyline mode, click to draw the bounding shape for the seating section.
The cursor changes to indicate placement of a focus line, and layout lines preview the seating angle for the focus line.
4.Click twice to place the seating section’s focus line. The first click controls the angle of straight seats or the radius of curved seats. The second click controls the focus point of the seats. When Display Focus Line is selected in the Object Info palette, the focus point end of the line is indicated by an arrow.
To associate the seating section with an aisle object (Spotlight required), put the seating section and the aisle on the same layer or in the same group; see Adding aisles to seating sections. This association means that if one of the objects is resized, reshaped, or moved, the other object updates automatically. The association between objects lasts only as long as the seating section and aisle physically overlap.
The settings are grouped into several panes of related parameters, which are listed on the left side of the dialog box. These parameters vary depending on whether a standard or curved seating type is selected. Select each pane and specify the parameters.
Every pane of the Seating Section Settings dialog box displays a preview of the seating section with the current settings; the preview updates dynamically as the settings are edited.
Creating plug-in object styles allows you to create plug-in objects, such as the seating section, with a combination of parameters that are determined by the style or by instance. Style parameters have a fixed value established by the style; instance parameters can be set independently for each instance of the object in the drawing.
Seating Section settings: Arrangement pane
Seating Section settings: Section Information pane
Seating Section settings: Limits pane
Seating Section settings: Angle pane
If the seating section object is four-sided and all four corners are 90°, you can specify an angle for the seating within the boundary.
Seating Section settings: Classes pane
