Design SuiteCreating doors, windows, and assemblies
Tool
Tool set
Shortcut
Door
Window
Door and Window Assembly
Building Shell
Door tool
Alt+Shift+D (Windows)
Option+Shift+D (Mac)
Window tool
Shift+D (Windows)
Option+Shift+W (Mac)
Use the Door tool, Window tool, and Door and Window Assembly tool to create objects based on a style resource and/or the parameters specified in the preferences dialog box. The objects can be created in Top/Plan view or in a 3D view. There are different methods for creating any of these objects:
Click to insert an object based on a style or the parameters in the preferences dialog box; see Inserting doors, windows, and assemblies.
Draw the object manually using a style or the parameters in the preferences dialog box; see Drawing doors, windows, and assemblies.
Door and window assemblies can be created from existing doors/windows, or from a closed 2D shape; see Creating a door and window assembly from existing objects. Although you can use the Door and Window Assembly tool to create an assembly, creating it from existing doors and windows in a wall is the recommended method.
To place a door or window into a curtain wall, use the Edit Wall tool; see Editing curtain wall panels. The object is automatically placed as a curtain wall door/window. The door/window's selected style or preferences are used as much as possible, while fitting the object within the curtain wall grid. Assemblies can be used as repeated elements in a curtain wall.
The same modes are available for all three tools.
Mode
Description
Standard Insertion
Inserts an object with the selected style or parameters specified in the preferences dialog box
Offset Insertion
Inserts an object according to an offset reference point; see Offset symbol insertion mode
Interactive Sizing Insertion
Draws an object manually, with the size and location indicated
Wall Insertion
Toggles between enabling and disabling object insertion into a wall; see Wall Insertion mode
Alignment modes
For Standard Insertion mode and Offset Insertion mode, these modes change the alignment of the insertion point along the X axis of the object; see The Symbol Insertion tool
Corner to Corner
For Interactive Sizing Insertion mode, defines the object by clicking two diagonal points
Center to Corner
For Interactive Sizing Insertion mode, defines the object by the distance from the center to one corner
[Object] Style
Opens the Resource Selector to select an object style for placement; double-click a resource to activate it
Preferences
Opens the [Object] Preferences dialog box, to set default parameters; see Door settings, Window settings, or Door and window assembly settings
Doors and Windows
Editing doors, windows, and assemblies
Editing a door and window assembly layout
Concept: Door and window assembly best practices
Concept: Plug-in object styles
Concept: Vectorworks symbols
Concept: Object instances, definitions, and styles
